Time Before: 0.02256 seconds
Time After: 0.02800 seconds
Time Taken: 0.00545 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.02810 seconds
Time After: 0.02852 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.02884 seconds
Time After: 0.02899 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.02981 seconds
Time After: 0.03214 seconds
Time Taken: 0.00233 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.02905 seconds
Time After: 0.03620 seconds
Time Taken: 0.00715 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.04400 seconds
Time After: 0.04437 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.04683 seconds
Time After: 0.04805 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.04324 seconds
Time After: 0.04824 seconds
Time Taken: 0.00500 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.08222 seconds
Time After: 0.08237 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.13735 seconds
Time After: 0.13859 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
End call of global.php: 0.14061784744263
Time Before: 0.16967 seconds
Time After: 0.16985 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.17614 seconds
Time After: 0.17762 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
SET lastactivity = 1772758496, location = '/forums/private.php?do=newpm&explain=1&u=16308'
Time Before: 0.20281 seconds
Time After: 0.20310 seconds
Memory Before: 5,997.766 KB
Memory After: 5,997.984 KB
Page generated in 0.20170903205872 seconds with 9 queries, spending 0.0078346729278564 doing MySQL queries and 0.19387435913086 doing PHP things.
