Time Before: 0.01040 seconds
Time After: 0.01297 seconds
Time Taken: 0.00257 seconds
Time Before: 0.01311 seconds
Time After: 0.01382 seconds
Time Taken: 0.00071 seconds
Time Before: 0.01415 seconds
Time After: 0.01430 seconds
Time Before: 0.01530 seconds
Time After: 0.01776 seconds
Time Taken: 0.00246 seconds
Time Before: 0.01439 seconds
Time After: 0.02233 seconds
Time Taken: 0.00794 seconds
Time Before: 0.02623 seconds
Time After: 0.02656 seconds
Time Before: 0.02854 seconds
Time After: 0.02979 seconds
Time Before: 0.02564 seconds
Time After: 0.03003 seconds
Time Taken: 0.00439 seconds
Memory After: 2,885.219 KB
Memory Used: 132.898 KB
Time Before: 0.05084 seconds
Time After: 0.05099 seconds
Memory Before: 3,438.320 KB
Memory After: 3,438.836 KB
Time Before: 0.06052 seconds
Time After: 0.06188 seconds
Time Taken: 0.00136 seconds
Memory Before: 3,526.016 KB
Memory After: 3,526.609 KB
End call of global.php: 0.064158916473389
Time Before: 0.06850 seconds
Time After: 0.06865 seconds
Memory Before: 4,163.914 KB
Memory After: 4,164.344 KB
Time Before: 0.07080 seconds
Time After: 0.07220 seconds
Time Taken: 0.00140 seconds
Memory Before: 4,445.453 KB
Memory After: 4,447.141 KB
SET lastactivity = 1789135956, location = '/forums/private.php?do=newpm&explain=1&u=16331'
Time Before: 0.08835 seconds
Time After: 0.08864 seconds
Memory Before: 4,911.148 KB
Memory After: 4,911.375 KB
Page generated in 0.087157964706421 seconds with 9 queries, spending 0.0082383155822754 doing MySQL queries and 0.078919649124146 doing PHP things.
