Time Before: 0.00135 seconds
Time After: 0.00178 seconds
Time Before: 0.00185 seconds
Time After: 0.00225 seconds
Time Before: 0.00249 seconds
Time After: 0.00267 seconds
Time Before: 0.00355 seconds
Time After: 0.00578 seconds
Time Taken: 0.00223 seconds
Time Before: 0.00274 seconds
Time After: 0.00924 seconds
Time Taken: 0.00650 seconds
Time Before: 0.01127 seconds
Time After: 0.01148 seconds
Time Before: 0.01455 seconds
Time After: 0.01576 seconds
Time Before: 0.01055 seconds
Time After: 0.01600 seconds
Time Taken: 0.00545 seconds
Time Before: 0.02243 seconds
Time After: 0.02255 seconds
Time Before: 0.02434 seconds
Time After: 0.02557 seconds
End call of global.php: 0.028284072875977
Time Before: 0.02992 seconds
Time After: 0.03009 seconds
Time Before: 0.03238 seconds
Time After: 0.03395 seconds
Time Taken: 0.00157 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=16344', badlocation = 1
Time Before: 0.04801 seconds
Time After: 0.04832 seconds
Memory Before: 4,911.938 KB
Memory After: 4,912.164 KB
Page generated in 0.047088146209717 seconds with 9 queries, spending 0.0076351165771484 doing MySQL queries and 0.039453029632568 doing PHP things.
