Time Before: 0.00560 seconds
Time After: 0.00667 seconds
Time Taken: 0.00107 seconds
Time Before: 0.00677 seconds
Time After: 0.00723 seconds
Time Before: 0.00747 seconds
Time After: 0.00764 seconds
Time Before: 0.00851 seconds
Time After: 0.01189 seconds
Time Taken: 0.00337 seconds
Time Before: 0.00772 seconds
Time After: 0.01539 seconds
Time Taken: 0.00767 seconds
Time Before: 0.01877 seconds
Time After: 0.01929 seconds
Time Before: 0.02082 seconds
Time After: 0.02200 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01812 seconds
Time After: 0.02224 seconds
Time Taken: 0.00413 seconds
Memory After: 2,261.836 KB
Time Before: 0.03555 seconds
Time After: 0.03601 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.04986 seconds
Time After: 0.05179 seconds
Time Taken: 0.00193 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.05843 seconds
Time After: 0.05860 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.06139 seconds
Time After: 0.06385 seconds
Time Taken: 0.00245 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1789139627, location = '/forums/private.php?do=newpm&explain=1&u=16433' WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.08229 seconds
Time After: 0.08272 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
