Time Before: 0.00178 seconds
Time After: 0.00233 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00241 seconds
Time After: 0.00296 seconds
Time Before: 0.00323 seconds
Time After: 0.00338 seconds
Time Before: 0.00405 seconds
Time After: 0.00675 seconds
Time Taken: 0.00271 seconds
Time Before: 0.00343 seconds
Time After: 0.01013 seconds
Time Taken: 0.00670 seconds
Time Before: 0.01205 seconds
Time After: 0.01242 seconds
Time Before: 0.01481 seconds
Time After: 0.01603 seconds
Time Before: 0.01151 seconds
Time After: 0.01620 seconds
Time Taken: 0.00469 seconds
Time Before: 0.02102 seconds
Time After: 0.02120 seconds
Time Before: 0.02329 seconds
Time After: 0.02457 seconds
Time Before: 0.02726 seconds
Time After: 0.02741 seconds
Time Before: 0.02930 seconds
Time After: 0.03072 seconds
UPDATE session SET lastactivity = 1776619925, location = '/forums/private.php?do=newpm&explain=1&u=16438', badlocation = 1 WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.04312 seconds
Time After: 0.04337 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
