Time Before: 0.00153 seconds
Time After: 0.00207 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00215 seconds
Time After: 0.00253 seconds
Time Before: 0.00276 seconds
Time After: 0.00295 seconds
Time Before: 0.00364 seconds
Time After: 0.00613 seconds
Time Taken: 0.00249 seconds
Time Before: 0.00300 seconds
Time After: 0.00949 seconds
Time Taken: 0.00649 seconds
Time Before: 0.01165 seconds
Time After: 0.01205 seconds
Time Before: 0.01489 seconds
Time After: 0.01621 seconds
Time Taken: 0.00132 seconds
Time Before: 0.01106 seconds
Time After: 0.01646 seconds
Time Taken: 0.00540 seconds
Time Before: 0.02287 seconds
Time After: 0.02309 seconds
Time Before: 0.02569 seconds
Time After: 0.02701 seconds
End call of global.php: 0.028688907623291
Time Before: 0.02996 seconds
Time After: 0.03010 seconds
Time Before: 0.03212 seconds
Time After: 0.03355 seconds
SET lastactivity = 1789112458, location = '/forums/private.php?do=newpm&explain=1&u=16442'
Time Before: 0.04621 seconds
Time After: 0.04651 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.045276880264282 seconds with 9 queries, spending 0.0081799030303955 doing MySQL queries and 0.037096977233887 doing PHP things.
