Time Before: 0.00132 seconds
Time After: 0.00194 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00201 seconds
Time After: 0.00257 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00289 seconds
Time After: 0.00302 seconds
Time Before: 0.00377 seconds
Time After: 0.00662 seconds
Time Taken: 0.00285 seconds
Time Before: 0.00307 seconds
Time After: 0.01000 seconds
Time Taken: 0.00693 seconds
Time Before: 0.01192 seconds
Time After: 0.01240 seconds
Time Before: 0.01496 seconds
Time After: 0.01625 seconds
Time Before: 0.01122 seconds
Time After: 0.01642 seconds
Time Taken: 0.00520 seconds
Time Before: 0.02113 seconds
Time After: 0.02137 seconds
Time Before: 0.02359 seconds
Time After: 0.02515 seconds
Time Taken: 0.00155 seconds
End call of global.php: 0.02674412727356
Time Before: 0.02823 seconds
Time After: 0.02838 seconds
Time Before: 0.03032 seconds
Time After: 0.03187 seconds
SET lastactivity = 1788913853, location = '/forums/private.php?do=newpm&explain=1&u=16475', badlocation = 1
Time Before: 0.04451 seconds
Time After: 0.04477 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.043582201004028 seconds with 9 queries, spending 0.0090703964233398 doing MySQL queries and 0.034511804580688 doing PHP things.
