Time Before: 0.00166 seconds
Time After: 0.00228 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00235 seconds
Time After: 0.00279 seconds
Time Before: 0.00300 seconds
Time After: 0.00317 seconds
Time Before: 0.00392 seconds
Time After: 0.00600 seconds
Time Taken: 0.00208 seconds
Time Before: 0.00322 seconds
Time After: 0.00937 seconds
Time Taken: 0.00615 seconds
Time Before: 0.01114 seconds
Time After: 0.01150 seconds
Time Before: 0.01396 seconds
Time After: 0.01535 seconds
Time Taken: 0.00139 seconds
Time Before: 0.01058 seconds
Time After: 0.01552 seconds
Time Taken: 0.00494 seconds
Time Before: 0.02050 seconds
Time After: 0.02068 seconds
Time Before: 0.02272 seconds
Time After: 0.02400 seconds
End call of global.php: 0.025676965713501
Time Before: 0.02702 seconds
Time After: 0.02719 seconds
Time Before: 0.02924 seconds
Time After: 0.03067 seconds
SET lastactivity = 1789029111, location = '/forums/private.php?do=newpm&explain=1&u=16487'
Time Before: 0.04350 seconds
Time After: 0.04393 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.042588949203491 seconds with 9 queries, spending 0.0079278945922852 doing MySQL queries and 0.034661054611206 doing PHP things.
