Time Before: 0.01705 seconds
Time After: 0.02302 seconds
Time Taken: 0.00597 seconds
Time Before: 0.02310 seconds
Time After: 0.02352 seconds
Time Before: 0.02374 seconds
Time After: 0.02389 seconds
Time Before: 0.02472 seconds
Time After: 0.02708 seconds
Time Taken: 0.00236 seconds
Time Before: 0.02394 seconds
Time After: 0.03215 seconds
Time Taken: 0.00821 seconds
Time Before: 0.03857 seconds
Time After: 0.03899 seconds
Time Before: 0.04216 seconds
Time After: 0.04334 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.03797 seconds
Time After: 0.04354 seconds
Time Taken: 0.00557 seconds
Memory After: 2,261.836 KB
Time Before: 0.06364 seconds
Time After: 0.06378 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.07297 seconds
Time After: 0.07503 seconds
Time Taken: 0.00206 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.076838970184326
Time Before: 0.08107 seconds
Time After: 0.08136 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.08432 seconds
Time After: 0.08584 seconds
Time Taken: 0.00152 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1788932211, location = '/forums/private.php?do=newpm&explain=1&u=16516'
Time Before: 0.10285 seconds
Time After: 0.10327 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
Page generated in 0.1017370223999 seconds with 9 queries, spending 0.0089578628540039 doing MySQL queries and 0.092779159545898 doing PHP things.
