Time Before: 0.01409 seconds
Time After: 0.02008 seconds
Time Taken: 0.00599 seconds
Time Before: 0.02017 seconds
Time After: 0.02060 seconds
Time Before: 0.02081 seconds
Time After: 0.02092 seconds
Time Before: 0.02166 seconds
Time After: 0.02437 seconds
Time Taken: 0.00271 seconds
Time Before: 0.02099 seconds
Time After: 0.02832 seconds
Time Taken: 0.00733 seconds
Time Before: 0.03456 seconds
Time After: 0.03496 seconds
Time Before: 0.03749 seconds
Time After: 0.03866 seconds
Time Taken: 0.00117 seconds
Time Before: 0.03375 seconds
Time After: 0.03886 seconds
Time Taken: 0.00512 seconds
Time Before: 0.05657 seconds
Time After: 0.05674 seconds
Time Before: 0.06907 seconds
Time After: 0.07032 seconds
End call of global.php: 0.073318004608154
Time Before: 0.07874 seconds
Time After: 0.07891 seconds
Time Before: 0.08197 seconds
Time After: 0.08342 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=16605'
Time Before: 0.09968 seconds
Time After: 0.09994 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.098681926727295 seconds with 9 queries, spending 0.0081326961517334 doing MySQL queries and 0.090549230575562 doing PHP things.
