Time Before: 0.02659 seconds
Time After: 0.03400 seconds
Time Taken: 0.00742 seconds
Time Before: 0.03411 seconds
Time After: 0.03497 seconds
Time Taken: 0.00086 seconds
Time Before: 0.03533 seconds
Time After: 0.03545 seconds
Time Before: 0.03628 seconds
Time After: 0.03884 seconds
Time Taken: 0.00256 seconds
Time Before: 0.03552 seconds
Time After: 0.04346 seconds
Time Taken: 0.00793 seconds
Time Before: 0.05261 seconds
Time After: 0.05280 seconds
Time Before: 0.05545 seconds
Time After: 0.05801 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.05193 seconds
Time After: 0.05824 seconds
Time Taken: 0.00631 seconds
Memory After: 2,261.836 KB
Time Before: 0.08841 seconds
Time After: 0.08859 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.10806 seconds
Time After: 0.11000 seconds
Time Taken: 0.00193 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.11944 seconds
Time After: 0.11962 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.12240 seconds
Time After: 0.12469 seconds
Time Taken: 0.00229 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1788899635, location = '/forums/private.php?do=newpm&explain=1&u=16627' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.14935 seconds
Time After: 0.15156 seconds
Time Taken: 0.00221 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
