Time Before: 0.03516 seconds
Time After: 0.03849 seconds
Time Taken: 0.00333 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.03860 seconds
Time After: 0.03895 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.03925 seconds
Time After: 0.03939 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.04021 seconds
Time After: 0.04262 seconds
Time Taken: 0.00242 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.03946 seconds
Time After: 0.04780 seconds
Time Taken: 0.00834 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.05389 seconds
Time After: 0.05429 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.05686 seconds
Time After: 0.05804 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.05321 seconds
Time After: 0.05827 seconds
Time Taken: 0.00506 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.10468 seconds
Time After: 0.10481 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.16504 seconds
Time After: 0.16629 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
Time Before: 0.20033 seconds
Time After: 0.20047 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.20525 seconds
Time After: 0.20670 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=16645', badlocation = 1 WHERE sessionhash = 'eaa8a3ac54cff5a66f956999e9bca4a9'
Time Before: 0.23776 seconds
Time After: 0.23810 seconds
Memory Before: 5,997.742 KB
Memory After: 5,997.961 KB
