Time Before: 0.02391 seconds
Time After: 0.03298 seconds
Time Taken: 0.00906 seconds
Time Before: 0.03309 seconds
Time After: 0.03356 seconds
Time Before: 0.03386 seconds
Time After: 0.03406 seconds
Time Before: 0.03482 seconds
Time After: 0.03744 seconds
Time Taken: 0.00262 seconds
Time Before: 0.03411 seconds
Time After: 0.04211 seconds
Time Taken: 0.00800 seconds
Time Before: 0.05410 seconds
Time After: 0.05449 seconds
Time Before: 0.05710 seconds
Time After: 0.05831 seconds
Time Before: 0.05333 seconds
Time After: 0.05858 seconds
Time Taken: 0.00525 seconds
Time Before: 0.11393 seconds
Time After: 0.11410 seconds
Time Before: 0.13114 seconds
Time After: 0.13241 seconds
End call of global.php: 0.13450312614441
Time Before: 0.14587 seconds
Time After: 0.14612 seconds
Time Before: 0.14883 seconds
Time After: 0.15039 seconds
Time Taken: 0.00156 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=16712'
Time Before: 0.17084 seconds
Time After: 0.17122 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.16967606544495 seconds with 9 queries, spending 0.0084936618804932 doing MySQL queries and 0.16118240356445 doing PHP things.
