Time Before: 0.01472 seconds
Time After: 0.01764 seconds
Time Taken: 0.00292 seconds
Time Before: 0.01771 seconds
Time After: 0.01831 seconds
Time Taken: 0.00059 seconds
Time Before: 0.01863 seconds
Time After: 0.01883 seconds
Time Before: 0.01989 seconds
Time After: 0.02223 seconds
Time Taken: 0.00233 seconds
Time Before: 0.01892 seconds
Time After: 0.02689 seconds
Time Taken: 0.00796 seconds
Time Before: 0.03337 seconds
Time After: 0.03380 seconds
Time Before: 0.03644 seconds
Time After: 0.03767 seconds
Time Before: 0.03265 seconds
Time After: 0.03792 seconds
Time Taken: 0.00527 seconds
Time Before: 0.07359 seconds
Time After: 0.07379 seconds
Time Before: 0.08768 seconds
Time After: 0.08896 seconds
Time Before: 0.09655 seconds
Time After: 0.09675 seconds
Time Before: 0.09957 seconds
Time After: 0.10103 seconds
UPDATE session SET lastactivity = 1785352367, location = '/forums/private.php?do=newpm&explain=1&u=16730' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.12108 seconds
Time After: 0.12881 seconds
Time Taken: 0.00773 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
