Time Before: 0.00332 seconds
Time After: 0.00453 seconds
Time Before: 0.00460 seconds
Time After: 0.00503 seconds
Time Before: 0.00525 seconds
Time After: 0.00541 seconds
Time Before: 0.00604 seconds
Time After: 0.00861 seconds
Time Taken: 0.00257 seconds
Time Before: 0.00546 seconds
Time After: 0.01394 seconds
Time Taken: 0.00848 seconds
Time Before: 0.01633 seconds
Time After: 0.01675 seconds
Time Before: 0.01843 seconds
Time After: 0.01964 seconds
Time Before: 0.01555 seconds
Time After: 0.01987 seconds
Time Taken: 0.00432 seconds
Time Before: 0.02826 seconds
Time After: 0.02842 seconds
Time Before: 0.03090 seconds
Time After: 0.03219 seconds
Time Before: 0.03667 seconds
Time After: 0.03685 seconds
Time Before: 0.03965 seconds
Time After: 0.04113 seconds
UPDATE session SET lastactivity = 1788893626, location = '/forums/private.php?do=newpm&explain=1&u=16766' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.05606 seconds
Time After: 0.05642 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
