Time Before: 0.00135 seconds
Time After: 0.00182 seconds
Time Before: 0.00189 seconds
Time After: 0.00317 seconds
Time Before: 0.00338 seconds
Time After: 0.00355 seconds
Time Before: 0.00418 seconds
Time After: 0.00748 seconds
Time Taken: 0.00330 seconds
Time Before: 0.00360 seconds
Time After: 0.01117 seconds
Time Taken: 0.00757 seconds
Time Before: 0.01309 seconds
Time After: 0.01345 seconds
Time Before: 0.01584 seconds
Time After: 0.01709 seconds
Time Before: 0.01248 seconds
Time After: 0.01736 seconds
Time Taken: 0.00488 seconds
Time Before: 0.02490 seconds
Time After: 0.02507 seconds
Time Before: 0.02747 seconds
Time After: 0.02875 seconds
Time Before: 0.03181 seconds
Time After: 0.03199 seconds
Time Before: 0.03468 seconds
Time After: 0.03613 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=16796' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04962 seconds
Time After: 0.04991 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
