Time Before: 0.02276 seconds
Time After: 0.02917 seconds
Time Taken: 0.00641 seconds
Time Before: 0.02927 seconds
Time After: 0.02969 seconds
Time Before: 0.02993 seconds
Time After: 0.03018 seconds
Time Before: 0.03100 seconds
Time After: 0.03309 seconds
Time Taken: 0.00209 seconds
Time Before: 0.03025 seconds
Time After: 0.03725 seconds
Time Taken: 0.00700 seconds
Time Before: 0.04708 seconds
Time After: 0.04747 seconds
Time Before: 0.05042 seconds
Time After: 0.05172 seconds
Time Taken: 0.00131 seconds
Time Before: 0.04633 seconds
Time After: 0.05198 seconds
Time Taken: 0.00565 seconds
Time Before: 0.10074 seconds
Time After: 0.10089 seconds
Time Before: 0.12209 seconds
Time After: 0.12333 seconds
End call of global.php: 0.12618899345398
Time Before: 0.13531 seconds
Time After: 0.13548 seconds
Time Before: 0.13871 seconds
Time After: 0.14014 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=16800'
Time Before: 0.16306 seconds
Time After: 0.16331 seconds
Memory Before: 4,288.555 KB
Memory After: 4,288.797 KB
Page generated in 0.16187191009521 seconds with 9 queries, spending 0.0077097415924072 doing MySQL queries and 0.15416216850281 doing PHP things.
