Time Before: 0.01101 seconds
Time After: 0.01403 seconds
Time Taken: 0.00302 seconds
Time Before: 0.01410 seconds
Time After: 0.01454 seconds
Time Before: 0.01479 seconds
Time After: 0.01495 seconds
Time Before: 0.01574 seconds
Time After: 0.01864 seconds
Time Taken: 0.00290 seconds
Time Before: 0.01499 seconds
Time After: 0.02322 seconds
Time Taken: 0.00822 seconds
Time Before: 0.02780 seconds
Time After: 0.02821 seconds
Time Before: 0.03072 seconds
Time After: 0.03204 seconds
Time Taken: 0.00132 seconds
Time Before: 0.02708 seconds
Time After: 0.03229 seconds
Time Taken: 0.00521 seconds
Time Before: 0.05635 seconds
Time After: 0.05651 seconds
Time Before: 0.06714 seconds
Time After: 0.06846 seconds
End call of global.php: 0.070837020874023
Time Before: 0.07342 seconds
Time After: 0.07365 seconds
Time Before: 0.07684 seconds
Time After: 0.07834 seconds
Time Taken: 0.00151 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=16836'
Time Before: 0.09765 seconds
Time After: 0.09834 seconds
Time Taken: 0.00069 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.096681833267212 seconds with 9 queries, spending 0.0090970993041992 doing MySQL queries and 0.087584733963013 doing PHP things.
