Time Before: 0.01279 seconds
Time After: 0.01985 seconds
Time Taken: 0.00706 seconds
Time Before: 0.01997 seconds
Time After: 0.02040 seconds
Time Before: 0.02064 seconds
Time After: 0.02084 seconds
Time Before: 0.02161 seconds
Time After: 0.02405 seconds
Time Taken: 0.00244 seconds
Time Before: 0.02093 seconds
Time After: 0.02817 seconds
Time Taken: 0.00724 seconds
Time Before: 0.03562 seconds
Time After: 0.03600 seconds
Time Before: 0.03851 seconds
Time After: 0.03975 seconds
Time Before: 0.03495 seconds
Time After: 0.03996 seconds
Time Taken: 0.00501 seconds
Time Before: 0.06111 seconds
Time After: 0.06126 seconds
Time Before: 0.07498 seconds
Time After: 0.07623 seconds
Time Before: 0.08255 seconds
Time After: 0.08271 seconds
Time Before: 0.08519 seconds
Time After: 0.08709 seconds
Time Taken: 0.00190 seconds
UPDATE session SET lastactivity = 1776632634, location = '/forums/private.php?do=newpm&explain=1&u=16857', badlocation = 1 WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.11073 seconds
Time After: 0.11103 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
