Time Before: 0.01509 seconds
Time After: 0.02248 seconds
Time Taken: 0.00739 seconds
Time Before: 0.02256 seconds
Time After: 0.02300 seconds
Time Before: 0.02325 seconds
Time After: 0.02338 seconds
Time Before: 0.02409 seconds
Time After: 0.02674 seconds
Time Taken: 0.00265 seconds
Time Before: 0.02344 seconds
Time After: 0.03040 seconds
Time Taken: 0.00696 seconds
Time Before: 0.03852 seconds
Time After: 0.03881 seconds
Time Before: 0.04133 seconds
Time After: 0.04272 seconds
Time Taken: 0.00139 seconds
Time Before: 0.03791 seconds
Time After: 0.04290 seconds
Time Taken: 0.00499 seconds
Time Before: 0.07706 seconds
Time After: 0.07723 seconds
Time Before: 0.13822 seconds
Time After: 0.13948 seconds
Time Before: 0.14854 seconds
Time After: 0.14872 seconds
Time Before: 0.15107 seconds
Time After: 0.15252 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=16875', badlocation = 1 WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.17345 seconds
Time After: 0.17370 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
