Time Before: 0.00395 seconds
Time After: 0.00516 seconds
Memory Before: 533.906 KB
Memory After: 559.023 KB
Time Before: 0.00526 seconds
Time After: 0.00602 seconds
Time Taken: 0.00076 seconds
Memory Before: 558.961 KB
Memory After: 559.969 KB
Time Before: 0.00640 seconds
Time After: 0.00656 seconds
Memory Before: 560.523 KB
Memory After: 561.047 KB
Time Before: 0.00743 seconds
Time After: 0.00978 seconds
Time Taken: 0.00235 seconds
Memory Before: 563.648 KB
Memory After: 564.570 KB
Time Before: 0.00663 seconds
Time After: 0.01470 seconds
Time Taken: 0.00807 seconds
Memory Before: 560.297 KB
Memory After: 1,641.297 KB
Memory Used: 1,081.000 KB
Time Before: 0.01668 seconds
Time After: 0.01706 seconds
Memory Before: 2,136.141 KB
Memory After: 2,136.758 KB
Time Before: 0.01937 seconds
Time After: 0.02057 seconds
Memory Before: 2,148.320 KB
Memory After: 2,148.180 KB
Time Before: 0.01609 seconds
Time After: 0.02075 seconds
Time Taken: 0.00466 seconds
Memory Before: 2,128.320 KB
Memory After: 2,261.203 KB
Time Before: 0.02622 seconds
Time After: 0.02636 seconds
Memory Before: 2,814.781 KB
Memory After: 2,815.297 KB
Time Before: 0.03152 seconds
Time After: 0.03284 seconds
Time Taken: 0.00132 seconds
Memory Before: 2,903.117 KB
Memory After: 2,903.711 KB
End call of global.php: 0.034510135650635
Time Before: 0.03566 seconds
Time After: 0.03587 seconds
Memory Before: 3,539.836 KB
Memory After: 3,540.266 KB
Time Before: 0.03889 seconds
Time After: 0.04037 seconds
Memory Before: 3,821.367 KB
Memory After: 3,823.055 KB
SET lastactivity = 1788886751, location = '/forums/private.php?do=newpm&explain=1&u=16876'
Time Before: 0.05339 seconds
Time After: 0.05367 seconds
Memory Before: 4,295.203 KB
Memory After: 4,295.430 KB
Page generated in 0.052499055862427 seconds with 9 queries, spending 0.0082800388336182 doing MySQL queries and 0.044219017028809 doing PHP things.
