Time Before: 0.00167 seconds
Time After: 0.00211 seconds
Time Before: 0.00218 seconds
Time After: 0.00267 seconds
Time Before: 0.00289 seconds
Time After: 0.00306 seconds
Time Before: 0.00374 seconds
Time After: 0.00635 seconds
Time Taken: 0.00260 seconds
Time Before: 0.00311 seconds
Time After: 0.00971 seconds
Time Taken: 0.00660 seconds
Time Before: 0.01191 seconds
Time After: 0.01251 seconds
Time Taken: 0.00059 seconds
Time Before: 0.01504 seconds
Time After: 0.01627 seconds
Time Before: 0.01121 seconds
Time After: 0.01645 seconds
Time Taken: 0.00524 seconds
Time Before: 0.02253 seconds
Time After: 0.02273 seconds
Time Before: 0.02463 seconds
Time After: 0.02588 seconds
Time Before: 0.02885 seconds
Time After: 0.02902 seconds
Time Before: 0.03108 seconds
Time After: 0.03251 seconds
UPDATE session SET lastactivity = 1776793066, location = '/forums/private.php?do=newpm&explain=1&u=16880', badlocation = 1 WHERE sessionhash = '84d505ff74940a4d05f0ae95a61eba7a'
Time Before: 0.04493 seconds
Time After: 0.04540 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
