Time Before: 0.01617 seconds
Time After: 0.02114 seconds
Time Taken: 0.00497 seconds
Time Before: 0.02125 seconds
Time After: 0.02163 seconds
Time Before: 0.02187 seconds
Time After: 0.02200 seconds
Time Before: 0.02272 seconds
Time After: 0.02530 seconds
Time Taken: 0.00258 seconds
Time Before: 0.02206 seconds
Time After: 0.02945 seconds
Time Taken: 0.00739 seconds
Time Before: 0.03506 seconds
Time After: 0.03545 seconds
Time Before: 0.03821 seconds
Time After: 0.03989 seconds
Time Taken: 0.00168 seconds
Time Before: 0.03430 seconds
Time After: 0.04013 seconds
Time Taken: 0.00583 seconds
Time Before: 0.06108 seconds
Time After: 0.06120 seconds
Time Before: 0.07597 seconds
Time After: 0.07726 seconds
Time Before: 0.08385 seconds
Time After: 0.08401 seconds
Time Before: 0.08631 seconds
Time After: 0.08775 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=16904' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.10321 seconds
Time After: 0.10355 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
