Time Before: 0.00159 seconds
Time After: 0.00203 seconds
Time Before: 0.00209 seconds
Time After: 0.00252 seconds
Time Before: 0.00272 seconds
Time After: 0.00286 seconds
Time Before: 0.00349 seconds
Time After: 0.00559 seconds
Time Taken: 0.00210 seconds
Time Before: 0.00290 seconds
Time After: 0.00896 seconds
Time Taken: 0.00606 seconds
Time Before: 0.01068 seconds
Time After: 0.01104 seconds
Time Before: 0.01403 seconds
Time After: 0.01526 seconds
Time Before: 0.01014 seconds
Time After: 0.01552 seconds
Time Taken: 0.00538 seconds
Time Before: 0.02329 seconds
Time After: 0.02342 seconds
Time Before: 0.02576 seconds
Time After: 0.02703 seconds
End call of global.php: 0.029753923416138
Time Before: 0.03118 seconds
Time After: 0.03133 seconds
Time Before: 0.03481 seconds
Time After: 0.03626 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=16907'
Time Before: 0.05084 seconds
Time After: 0.05129 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.049726009368896 seconds with 9 queries, spending 0.0076968669891357 doing MySQL queries and 0.042029142379761 doing PHP things.
