Time Before: 0.00145 seconds
Time After: 0.00197 seconds
Time Before: 0.00203 seconds
Time After: 0.00241 seconds
Time Before: 0.00262 seconds
Time After: 0.00274 seconds
Time Before: 0.00345 seconds
Time After: 0.00630 seconds
Time Taken: 0.00285 seconds
Time Before: 0.00279 seconds
Time After: 0.01029 seconds
Time Taken: 0.00750 seconds
Time Before: 0.01267 seconds
Time After: 0.01319 seconds
Time Before: 0.01589 seconds
Time After: 0.01728 seconds
Time Taken: 0.00139 seconds
Time Before: 0.01192 seconds
Time After: 0.01747 seconds
Time Taken: 0.00555 seconds
Time Before: 0.02243 seconds
Time After: 0.02256 seconds
Time Before: 0.02437 seconds
Time After: 0.02556 seconds
End call of global.php: 0.027215003967285
Time Before: 0.02838 seconds
Time After: 0.02852 seconds
Time Before: 0.03053 seconds
Time After: 0.03194 seconds
SET lastactivity = 1789065430, location = '/forums/private.php?do=newpm&explain=1&u=16921', badlocation = 1
Time Before: 0.04462 seconds
Time After: 0.04492 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.043703079223633 seconds with 9 queries, spending 0.0084242820739746 doing MySQL queries and 0.035278797149658 doing PHP things.
