Time Before: 0.00159 seconds
Time After: 0.00220 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00228 seconds
Time After: 0.00265 seconds
Time Before: 0.00288 seconds
Time After: 0.00302 seconds
Time Before: 0.00390 seconds
Time After: 0.00651 seconds
Time Taken: 0.00262 seconds
Time Before: 0.00307 seconds
Time After: 0.01049 seconds
Time Taken: 0.00742 seconds
Time Before: 0.01268 seconds
Time After: 0.01307 seconds
Time Before: 0.01571 seconds
Time After: 0.01697 seconds
Time Before: 0.01203 seconds
Time After: 0.01718 seconds
Time Taken: 0.00514 seconds
Time Before: 0.02234 seconds
Time After: 0.02249 seconds
Time Before: 0.02432 seconds
Time After: 0.02582 seconds
Time Taken: 0.00150 seconds
Time Before: 0.02883 seconds
Time After: 0.02903 seconds
Time Before: 0.03150 seconds
Time After: 0.03300 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=17016', badlocation = 1 WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.05085 seconds
Time After: 0.05143 seconds
Time Taken: 0.00058 seconds
Memory Before: 4,911.938 KB
Memory After: 4,912.164 KB
