Time Before: 0.00180 seconds
Time After: 0.00240 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00251 seconds
Time After: 0.00297 seconds
Time Before: 0.00316 seconds
Time After: 0.00327 seconds
Time Before: 0.00393 seconds
Time After: 0.00635 seconds
Time Taken: 0.00242 seconds
Time Before: 0.00332 seconds
Time After: 0.01035 seconds
Time Taken: 0.00703 seconds
Time Before: 0.01259 seconds
Time After: 0.01297 seconds
Time Before: 0.01547 seconds
Time After: 0.01691 seconds
Time Before: 0.01194 seconds
Time After: 0.01707 seconds
Time Taken: 0.00514 seconds
Time Before: 0.02213 seconds
Time After: 0.02226 seconds
Time Before: 0.02406 seconds
Time After: 0.02529 seconds
Time Before: 0.02826 seconds
Time After: 0.02841 seconds
Time Before: 0.03096 seconds
Time After: 0.03240 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=17021', badlocation = 1 WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.04741 seconds
Time After: 0.04774 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
