Time Before: 0.01118 seconds
Time After: 0.01404 seconds
Time Taken: 0.00286 seconds
Time Before: 0.01411 seconds
Time After: 0.01457 seconds
Time Before: 0.01488 seconds
Time After: 0.01503 seconds
Time Before: 0.01604 seconds
Time After: 0.01838 seconds
Time Taken: 0.00233 seconds
Time Before: 0.01511 seconds
Time After: 0.02214 seconds
Time Taken: 0.00703 seconds
Time Before: 0.02734 seconds
Time After: 0.02778 seconds
Time Before: 0.03092 seconds
Time After: 0.03210 seconds
Time Before: 0.02668 seconds
Time After: 0.03230 seconds
Time Taken: 0.00562 seconds
Time Before: 0.05026 seconds
Time After: 0.05041 seconds
Time Before: 0.06021 seconds
Time After: 0.06156 seconds
Time Taken: 0.00135 seconds
Time Before: 0.07084 seconds
Time After: 0.07099 seconds
Time Before: 0.07363 seconds
Time After: 0.07506 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=17096', badlocation = 1 WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.09233 seconds
Time After: 0.09269 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
