Time Before: 0.02718 seconds
Time After: 0.03471 seconds
Time Taken: 0.00752 seconds
Time Before: 0.03481 seconds
Time After: 0.03525 seconds
Time Before: 0.03550 seconds
Time After: 0.03566 seconds
Time Before: 0.03647 seconds
Time After: 0.03853 seconds
Time Taken: 0.00206 seconds
Time Before: 0.03575 seconds
Time After: 0.04256 seconds
Time Taken: 0.00681 seconds
Time Before: 0.05010 seconds
Time After: 0.05073 seconds
Time Taken: 0.00062 seconds
Time Before: 0.05372 seconds
Time After: 0.05497 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.04941 seconds
Time After: 0.05518 seconds
Time Taken: 0.00577 seconds
Memory After: 2,261.719 KB
Time Before: 0.09106 seconds
Time After: 0.09196 seconds
Time Taken: 0.00089 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.11520 seconds
Time After: 0.11725 seconds
Time Taken: 0.00205 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.11962199211121
Time Before: 0.12648 seconds
Time After: 0.12683 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.12937 seconds
Time After: 0.13143 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=17138'
Time Before: 0.15297 seconds
Time After: 0.15338 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
Page generated in 0.15181183815002 seconds with 9 queries, spending 0.010313272476196 doing MySQL queries and 0.14149856567383 doing PHP things.
