Time Before: 0.00344 seconds
Time After: 0.00408 seconds
Time Taken: 0.00064 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.00415 seconds
Time After: 0.00468 seconds
Time Taken: 0.00053 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.00495 seconds
Time After: 0.00513 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.00608 seconds
Time After: 0.00889 seconds
Time Taken: 0.00281 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.00521 seconds
Time After: 0.01351 seconds
Time Taken: 0.00830 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.01554 seconds
Time After: 0.01595 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.01928 seconds
Time After: 0.02052 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.01489 seconds
Time After: 0.02071 seconds
Time Taken: 0.00583 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.02704 seconds
Time After: 0.02718 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.03443 seconds
Time After: 0.03570 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
End call of global.php: 0.037482023239136
Time Before: 0.04390 seconds
Time After: 0.04407 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.04708 seconds
Time After: 0.04852 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=17213', badlocation = 1
WHERE sessionhash = 'a1024cf3a534e5ec94f7248e61d8a1ae'
Time Before: 0.06340 seconds
Time After: 0.06372 seconds
Memory Before: 5,997.742 KB
Memory After: 5,997.961 KB
Page generated in 0.062453031539917 seconds with 9 queries, spending 0.0085148811340332 doing MySQL queries and 0.053938150405884 doing PHP things.
