Time Before: 0.02481 seconds
Time After: 0.03092 seconds
Time Taken: 0.00611 seconds
Memory Before: 533.906 KB
Memory After: 559.023 KB
Time Before: 0.03103 seconds
Time After: 0.03141 seconds
Memory Before: 558.961 KB
Memory After: 559.969 KB
Time Before: 0.03209 seconds
Time After: 0.03223 seconds
Memory Before: 560.523 KB
Memory After: 561.047 KB
Time Before: 0.03306 seconds
Time After: 0.03579 seconds
Time Taken: 0.00273 seconds
Memory Before: 563.648 KB
Memory After: 564.570 KB
Time Before: 0.03229 seconds
Time After: 0.03983 seconds
Time Taken: 0.00754 seconds
Memory Before: 560.297 KB
Memory After: 1,641.297 KB
Memory Used: 1,081.000 KB
Time Before: 0.04953 seconds
Time After: 0.05044 seconds
Time Taken: 0.00092 seconds
Memory Before: 2,136.141 KB
Memory After: 2,136.758 KB
Time Before: 0.05318 seconds
Time After: 0.05560 seconds
Time Taken: 0.00242 seconds
Memory Before: 2,148.203 KB
Memory After: 2,148.063 KB
Time Before: 0.04833 seconds
Time After: 0.05588 seconds
Memory Before: 2,128.320 KB
Memory After: 2,261.086 KB
Time Before: 0.08638 seconds
Time After: 0.08653 seconds
Memory Before: 2,814.633 KB
Memory After: 2,815.148 KB
Time Before: 0.10912 seconds
Time After: 0.11042 seconds
Memory Before: 2,902.938 KB
Memory After: 2,903.531 KB
End call of global.php: 0.1122419834137
Time Before: 0.12080 seconds
Time After: 0.12102 seconds
Memory Before: 3,539.703 KB
Memory After: 3,540.133 KB
Time Before: 0.12339 seconds
Time After: 0.12484 seconds
Memory Before: 3,821.234 KB
Memory After: 3,822.922 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=17319'
Time Before: 0.14325 seconds
Time After: 0.14351 seconds
Memory Before: 4,294.844 KB
Memory After: 4,295.086 KB
Page generated in 0.14219188690186 seconds with 9 queries, spending 0.0099771022796631 doing MySQL queries and 0.13221478462219 doing PHP things.
