Time Before: 0.02975 seconds
Time After: 0.04051 seconds
Time Taken: 0.01075 seconds
Time Before: 0.04062 seconds
Time After: 0.04103 seconds
Time Before: 0.04128 seconds
Time After: 0.04142 seconds
Time Before: 0.04230 seconds
Time After: 0.04495 seconds
Time Taken: 0.00266 seconds
Time Before: 0.04149 seconds
Time After: 0.04943 seconds
Time Taken: 0.00794 seconds
Time Before: 0.05869 seconds
Time After: 0.05908 seconds
Time Before: 0.06063 seconds
Time After: 0.06182 seconds
Time Before: 0.05796 seconds
Time After: 0.06204 seconds
Time Taken: 0.00407 seconds
Time Before: 0.09574 seconds
Time After: 0.09588 seconds
Time Before: 0.36053 seconds
Time After: 0.36216 seconds
Time Taken: 0.00163 seconds
End call of global.php: 0.36423897743225
Time Before: 0.37361 seconds
Time After: 0.37377 seconds
Time Before: 0.37626 seconds
Time After: 0.37928 seconds
Time Taken: 0.00302 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=17329'
Time Before: 0.39863 seconds
Time After: 0.39902 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.39747309684753 seconds with 9 queries, spending 0.010118961334229 doing MySQL queries and 0.38735413551331 doing PHP things.
