Time Before: 0.00334 seconds
Time After: 0.00394 seconds
Time Taken: 0.00060 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.00404 seconds
Time After: 0.00441 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.00461 seconds
Time After: 0.00474 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.00557 seconds
Time After: 0.00849 seconds
Time Taken: 0.00292 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.00482 seconds
Time After: 0.01360 seconds
Time Taken: 0.00878 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.01570 seconds
Time After: 0.01612 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.01877 seconds
Time After: 0.01997 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.01507 seconds
Time After: 0.02022 seconds
Time Taken: 0.00515 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.02741 seconds
Time After: 0.02754 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.03465 seconds
Time After: 0.03590 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
End call of global.php: 0.037681102752686
Time Before: 0.04426 seconds
Time After: 0.04447 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.04662 seconds
Time After: 0.04808 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
SET lastactivity = 1764942887, location = '/forums/private.php?do=newpm&explain=1&u=17374', badlocation = 1
WHERE sessionhash = '453ba7501e81fc6b6d33fc68a24ebb23'
Time Before: 0.06223 seconds
Time After: 0.06253 seconds
Memory Before: 5,998.055 KB
Memory After: 5,998.250 KB
Memory Used: 0.195 KB
Page generated in 0.061256885528564 seconds with 9 queries, spending 0.0083658695220947 doing MySQL queries and 0.05289101600647 doing PHP things.
