Time Before: 0.01080 seconds
Time After: 0.01308 seconds
Time Taken: 0.00228 seconds
Memory Before: 534.492 KB
Memory After: 559.609 KB
Time Before: 0.01318 seconds
Time After: 0.01358 seconds
Memory Before: 559.547 KB
Memory After: 560.555 KB
Time Before: 0.01379 seconds
Time After: 0.01391 seconds
Memory Before: 561.109 KB
Memory After: 561.633 KB
Time Before: 0.01474 seconds
Time After: 0.01754 seconds
Time Taken: 0.00280 seconds
Memory Before: 564.234 KB
Memory After: 565.156 KB
Time Before: 0.01396 seconds
Time After: 0.02176 seconds
Time Taken: 0.00780 seconds
Memory Before: 560.883 KB
Memory After: 1,641.914 KB
Time Before: 0.02805 seconds
Time After: 0.02844 seconds
Time Before: 0.03011 seconds
Time After: 0.03136 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.02734 seconds
Time After: 0.03155 seconds
Time Taken: 0.00421 seconds
Memory After: 2,261.820 KB
Time Before: 0.06218 seconds
Time After: 0.06250 seconds
Memory Before: 2,815.414 KB
Memory After: 2,815.930 KB
Time Before: 0.07457 seconds
Time After: 0.07582 seconds
Memory Before: 2,903.719 KB
Memory After: 2,904.313 KB
End call of global.php: 0.078312873840332
Time Before: 0.08657 seconds
Time After: 0.08672 seconds
Memory Before: 3,540.484 KB
Memory After: 3,540.914 KB
Time Before: 0.08916 seconds
Time After: 0.09058 seconds
Memory Before: 3,822.031 KB
Memory After: 3,823.703 KB
Memory Used: 1.672 KB
SET lastactivity = 1785301979, location = '/forums/private.php?do=newpm&explain=1&u=17407'
Time Before: 0.10759 seconds
Time After: 0.10801 seconds
Memory Before: 4,295.875 KB
Memory After: 4,296.102 KB
Page generated in 0.10650897026062 seconds with 9 queries, spending 0.0085110664367676 doing MySQL queries and 0.097997903823853 doing PHP things.
