Time Before: 0.00199 seconds
Time After: 0.00261 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00272 seconds
Time After: 0.00334 seconds
Time Before: 0.00360 seconds
Time After: 0.00373 seconds
Time Before: 0.00462 seconds
Time After: 0.00918 seconds
Time Taken: 0.00456 seconds
Time Before: 0.00381 seconds
Time After: 0.01326 seconds
Time Taken: 0.00944 seconds
Time Before: 0.01504 seconds
Time After: 0.01545 seconds
Time Before: 0.01842 seconds
Time After: 0.01958 seconds
Time Taken: 0.00116 seconds
Time Before: 0.01443 seconds
Time After: 0.01977 seconds
Time Taken: 0.00534 seconds
Time Before: 0.02533 seconds
Time After: 0.02546 seconds
Time Before: 0.02838 seconds
Time After: 0.02970 seconds
Time Taken: 0.00133 seconds
Time Before: 0.03316 seconds
Time After: 0.03341 seconds
Time Before: 0.03628 seconds
Time After: 0.03778 seconds
Time Taken: 0.00150 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=17474', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.05184 seconds
Time After: 0.05216 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
