Time Before: 0.00790 seconds
Time After: 0.01013 seconds
Time Taken: 0.00224 seconds
Time Before: 0.01023 seconds
Time After: 0.01063 seconds
Time Before: 0.01086 seconds
Time After: 0.01098 seconds
Time Before: 0.01178 seconds
Time After: 0.01444 seconds
Time Taken: 0.00266 seconds
Time Before: 0.01102 seconds
Time After: 0.01908 seconds
Time Taken: 0.00806 seconds
Time Before: 0.02342 seconds
Time After: 0.02381 seconds
Time Before: 0.02529 seconds
Time After: 0.02649 seconds
Time Before: 0.02270 seconds
Time After: 0.02670 seconds
Time Taken: 0.00399 seconds
Time Before: 0.04200 seconds
Time After: 0.04217 seconds
Time Before: 0.04922 seconds
Time After: 0.05099 seconds
Time Taken: 0.00177 seconds
Time Before: 0.05622 seconds
Time After: 0.05638 seconds
Time Before: 0.05913 seconds
Time After: 0.06056 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=17533' WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.07753 seconds
Time After: 0.07784 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
