Time Before: 0.00174 seconds
Time After: 0.00233 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00240 seconds
Time After: 0.00301 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00332 seconds
Time After: 0.00347 seconds
Time Before: 0.00417 seconds
Time After: 0.00667 seconds
Time Taken: 0.00250 seconds
Time Before: 0.00353 seconds
Time After: 0.01006 seconds
Time Taken: 0.00653 seconds
Time Before: 0.01203 seconds
Time After: 0.01241 seconds
Time Before: 0.01488 seconds
Time After: 0.01615 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01138 seconds
Time After: 0.01637 seconds
Time Taken: 0.00500 seconds
Memory After: 2,261.836 KB
Time Before: 0.02209 seconds
Time After: 0.02236 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.02448 seconds
Time After: 0.02576 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.027396202087402
Time Before: 0.02848 seconds
Time After: 0.02867 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.03066 seconds
Time After: 0.03294 seconds
Time Taken: 0.00228 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1788917985, location = '/forums/private.php?do=newpm&explain=1&u=17559', badlocation = 1
Time Before: 0.04533 seconds
Time After: 0.04563 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
Page generated in 0.044428110122681 seconds with 9 queries, spending 0.0092458724975586 doing MySQL queries and 0.035182237625122 doing PHP things.
