Time Before: 0.00939 seconds
Time After: 0.01246 seconds
Time Taken: 0.00307 seconds
Time Before: 0.01256 seconds
Time After: 0.01422 seconds
Time Taken: 0.00166 seconds
Time Before: 0.01481 seconds
Time After: 0.01493 seconds
Time Before: 0.01559 seconds
Time After: 0.01822 seconds
Time Taken: 0.00263 seconds
Time Before: 0.01499 seconds
Time After: 0.02224 seconds
Time Taken: 0.00725 seconds
Time Before: 0.02584 seconds
Time After: 0.02616 seconds
Time Before: 0.02814 seconds
Time After: 0.03056 seconds
Time Taken: 0.00242 seconds
Time Before: 0.02525 seconds
Time After: 0.03083 seconds
Time Taken: 0.00559 seconds
Time Before: 0.05031 seconds
Time After: 0.05045 seconds
Time Before: 0.06072 seconds
Time After: 0.06196 seconds
End call of global.php: 0.064475059509277
Time Before: 0.06799 seconds
Time After: 0.06815 seconds
Time Before: 0.07127 seconds
Time After: 0.07270 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=17572', badlocation = 1
Time Before: 0.09287 seconds
Time After: 0.09317 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.091490983963013 seconds with 9 queries, spending 0.010425806045532 doing MySQL queries and 0.08106517791748 doing PHP things.
