Time Before: 0.00216 seconds
Time After: 0.00284 seconds
Time Taken: 0.00068 seconds
Memory Before: 532.305 KB
Memory After: 557.422 KB
Time Before: 0.00294 seconds
Time After: 0.00353 seconds
Time Taken: 0.00059 seconds
Memory Before: 557.359 KB
Memory After: 558.367 KB
Time Before: 0.00373 seconds
Time After: 0.00386 seconds
Memory Before: 558.922 KB
Memory After: 559.445 KB
Time Before: 0.00449 seconds
Time After: 0.00720 seconds
Time Taken: 0.00271 seconds
Memory Before: 562.047 KB
Memory After: 562.969 KB
Time Before: 0.00390 seconds
Time After: 0.01053 seconds
Time Taken: 0.00663 seconds
Memory Before: 558.695 KB
Memory After: 1,639.742 KB
Memory Used: 1,081.047 KB
Time Before: 0.01225 seconds
Time After: 0.01271 seconds
Memory Before: 2,134.648 KB
Memory After: 2,135.266 KB
Time Before: 0.01517 seconds
Time After: 0.01645 seconds
Memory Before: 2,146.828 KB
Memory After: 2,146.688 KB
Time Before: 0.01168 seconds
Time After: 0.01664 seconds
Time Taken: 0.00495 seconds
Memory Before: 2,126.828 KB
Memory After: 2,260.039 KB
Memory Used: 133.211 KB
Time Before: 0.02291 seconds
Time After: 0.02312 seconds
Memory Before: 2,813.602 KB
Memory After: 2,814.117 KB
Time Before: 0.02577 seconds
Time After: 0.02698 seconds
Memory Before: 2,901.891 KB
Memory After: 2,902.484 KB
End call of global.php: 0.028638124465942
Time Before: 0.02978 seconds
Time After: 0.02991 seconds
Memory Before: 3,538.641 KB
Memory After: 3,539.070 KB
Time Before: 0.03182 seconds
Time After: 0.03325 seconds
Memory Before: 3,820.375 KB
Memory After: 3,822.063 KB
SET lastactivity = 1788987766, location = '/forums/private.php?do=newpm&explain=1&u=17668', badlocation = 1
Time Before: 0.04542 seconds
Time After: 0.04578 seconds
Memory Before: 4,298.813 KB
Memory After: 4,299.023 KB
Page generated in 0.044574022293091 seconds with 9 queries, spending 0.0085160732269287 doing MySQL queries and 0.036057949066162 doing PHP things.
