Time Before: 0.00200 seconds
Time After: 0.00279 seconds
Time Taken: 0.00079 seconds
Memory Before: 533.906 KB
Memory After: 559.023 KB
Time Before: 0.00290 seconds
Time After: 0.00338 seconds
Memory Before: 558.961 KB
Memory After: 559.969 KB
Time Before: 0.00365 seconds
Time After: 0.00385 seconds
Memory Before: 560.523 KB
Memory After: 561.047 KB
Time Before: 0.00480 seconds
Time After: 0.00815 seconds
Time Taken: 0.00335 seconds
Memory Before: 563.648 KB
Memory After: 564.570 KB
Time Before: 0.00393 seconds
Time After: 0.01269 seconds
Time Taken: 0.00876 seconds
Memory Before: 560.297 KB
Memory After: 1,641.297 KB
Memory Used: 1,081.000 KB
Time Before: 0.01489 seconds
Time After: 0.01508 seconds
Memory Before: 2,136.141 KB
Memory After: 2,136.758 KB
Time Before: 0.01758 seconds
Time After: 0.01885 seconds
Memory Before: 2,148.320 KB
Memory After: 2,148.180 KB
Time Before: 0.01432 seconds
Time After: 0.01914 seconds
Time Taken: 0.00482 seconds
Memory Before: 2,128.320 KB
Memory After: 2,261.203 KB
Time Before: 0.02728 seconds
Time After: 0.02745 seconds
Memory Before: 2,814.781 KB
Memory After: 2,815.297 KB
Time Before: 0.03018 seconds
Time After: 0.03143 seconds
Memory Before: 2,903.117 KB
Memory After: 2,903.711 KB
End call of global.php: 0.033114910125732
Time Before: 0.03427 seconds
Time After: 0.03444 seconds
Memory Before: 3,539.836 KB
Memory After: 3,540.266 KB
Time Before: 0.03698 seconds
Time After: 0.03845 seconds
Memory Before: 3,821.367 KB
Memory After: 3,823.055 KB
SET lastactivity = 1788903453, location = '/forums/private.php?do=newpm&explain=1&u=17685'
Time Before: 0.05324 seconds
Time After: 0.05349 seconds
Memory Before: 4,295.203 KB
Memory After: 4,295.430 KB
Page generated in 0.052125930786133 seconds with 9 queries, spending 0.0088191032409668 doing MySQL queries and 0.043306827545166 doing PHP things.
