Time Before: 0.00455 seconds
Time After: 0.00602 seconds
Time Before: 0.00615 seconds
Time After: 0.00689 seconds
Time Taken: 0.00075 seconds
Time Before: 0.00716 seconds
Time After: 0.00734 seconds
Time Before: 0.00819 seconds
Time After: 0.01061 seconds
Time Taken: 0.00242 seconds
Time Before: 0.00741 seconds
Time After: 0.01560 seconds
Time Taken: 0.00819 seconds
Time Before: 0.01833 seconds
Time After: 0.01856 seconds
Time Before: 0.02005 seconds
Time After: 0.02133 seconds
Time Before: 0.01761 seconds
Time After: 0.02159 seconds
Time Taken: 0.00398 seconds
Time Before: 0.03095 seconds
Time After: 0.03114 seconds
Time Before: 0.03470 seconds
Time After: 0.03675 seconds
Time Taken: 0.00206 seconds
Time Before: 0.04091 seconds
Time After: 0.04107 seconds
Time Before: 0.04427 seconds
Time After: 0.04574 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=17908' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.06523 seconds
Time After: 0.06567 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
