Time Before: 0.00942 seconds
Time After: 0.01143 seconds
Time Taken: 0.00201 seconds
Time Before: 0.01153 seconds
Time After: 0.01199 seconds
Time Before: 0.01227 seconds
Time After: 0.01243 seconds
Time Before: 0.01331 seconds
Time After: 0.01531 seconds
Time Taken: 0.00200 seconds
Time Before: 0.01251 seconds
Time After: 0.01958 seconds
Time Taken: 0.00707 seconds
Time Before: 0.02408 seconds
Time After: 0.02450 seconds
Time Before: 0.02703 seconds
Time After: 0.02824 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.02322 seconds
Time After: 0.02845 seconds
Time Taken: 0.00523 seconds
Memory After: 2,261.719 KB
Time Before: 0.04316 seconds
Time After: 0.04332 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.05258 seconds
Time After: 0.05388 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.06138 seconds
Time After: 0.06154 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.06389 seconds
Time After: 0.06535 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=17933' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.08255 seconds
Time After: 0.08290 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
