Time Before: 0.01227 seconds
Time After: 0.01526 seconds
Time Taken: 0.00299 seconds
Time Before: 0.01535 seconds
Time After: 0.01583 seconds
Time Before: 0.01604 seconds
Time After: 0.01617 seconds
Time Before: 0.01702 seconds
Time After: 0.01963 seconds
Time Taken: 0.00261 seconds
Time Before: 0.01622 seconds
Time After: 0.02493 seconds
Time Taken: 0.00871 seconds
Time Before: 0.03117 seconds
Time After: 0.03166 seconds
Time Before: 0.03518 seconds
Time After: 0.03642 seconds
Time Before: 0.03046 seconds
Time After: 0.03664 seconds
Time Taken: 0.00618 seconds
Time Before: 0.06347 seconds
Time After: 0.06362 seconds
Time Before: 0.07452 seconds
Time After: 0.07578 seconds
Time Before: 0.08623 seconds
Time After: 0.08640 seconds
Time Before: 0.08920 seconds
Time After: 0.09063 seconds
UPDATE session SET lastactivity = 1785479063, location = '/forums/private.php?do=newpm&explain=1&u=17974', badlocation = 1 WHERE sessionhash = 'f787d15acff2abe23491441932164758'
Time Before: 0.10595 seconds
Time After: 0.10627 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
