Time Before: 0.01200 seconds
Time After: 0.01640 seconds
Time Taken: 0.00440 seconds
Time Before: 0.01651 seconds
Time After: 0.01698 seconds
Time Before: 0.01731 seconds
Time After: 0.01748 seconds
Time Before: 0.01830 seconds
Time After: 0.02021 seconds
Time Taken: 0.00191 seconds
Time Before: 0.01753 seconds
Time After: 0.02457 seconds
Time Taken: 0.00704 seconds
Time Before: 0.03276 seconds
Time After: 0.03312 seconds
Time Before: 0.03565 seconds
Time After: 0.03687 seconds
Time Before: 0.03209 seconds
Time After: 0.03708 seconds
Time Taken: 0.00499 seconds
Time Before: 0.05153 seconds
Time After: 0.05170 seconds
Time Before: 0.06640 seconds
Time After: 0.06826 seconds
Time Taken: 0.00186 seconds
End call of global.php: 0.07062816619873
Time Before: 0.07731 seconds
Time After: 0.07751 seconds
Time Before: 0.08023 seconds
Time After: 0.08173 seconds
Time Taken: 0.00150 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=18009', badlocation = 1
WHERE sessionhash = 'fb8546df1d172120a5a514bbe0406f9a'
Time Before: 0.10110 seconds
Time After: 0.10157 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.099936008453369 seconds with 9 queries, spending 0.00832200050354 doing MySQL queries and 0.091614007949829 doing PHP things.
