Time Before: 0.01618 seconds
Time After: 0.02106 seconds
Time Taken: 0.00488 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.02119 seconds
Time After: 0.02167 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.02196 seconds
Time After: 0.02219 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.02310 seconds
Time After: 0.02840 seconds
Time Taken: 0.00530 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.02227 seconds
Time After: 0.03348 seconds
Time Taken: 0.01121 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.03867 seconds
Time After: 0.03913 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.04068 seconds
Time After: 0.04184 seconds
Time Taken: 0.00116 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.03792 seconds
Time After: 0.04209 seconds
Time Taken: 0.00417 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.06857 seconds
Time After: 0.06874 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.10995 seconds
Time After: 0.11118 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
Time Before: 0.13062 seconds
Time After: 0.13085 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.13493 seconds
Time After: 0.13653 seconds
Time Taken: 0.00161 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=18159', badlocation = 1 WHERE sessionhash = 'fb8546df1d172120a5a514bbe0406f9a'
Time Before: 0.15779 seconds
Time After: 0.15809 seconds
Memory Before: 5,998.492 KB
Memory After: 5,998.711 KB
