Time Before: 0.00134 seconds
Time After: 0.00177 seconds
Time Before: 0.00183 seconds
Time After: 0.00226 seconds
Time Before: 0.00247 seconds
Time After: 0.00267 seconds
Time Before: 0.00374 seconds
Time After: 0.00673 seconds
Time Taken: 0.00299 seconds
Time Before: 0.00275 seconds
Time After: 0.01127 seconds
Time Taken: 0.00852 seconds
Time Before: 0.01364 seconds
Time After: 0.01404 seconds
Time Before: 0.01688 seconds
Time After: 0.01810 seconds
Time Before: 0.01300 seconds
Time After: 0.01836 seconds
Time Taken: 0.00536 seconds
Time Before: 0.02548 seconds
Time After: 0.02562 seconds
Time Before: 0.02912 seconds
Time After: 0.03037 seconds
Time Before: 0.03378 seconds
Time After: 0.03392 seconds
Time Before: 0.03650 seconds
Time After: 0.03793 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=18162' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.05259 seconds
Time After: 0.05286 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
