Time Before: 0.01502 seconds
Time After: 0.01890 seconds
Time Taken: 0.00389 seconds
Time Before: 0.01900 seconds
Time After: 0.01945 seconds
Time Before: 0.01974 seconds
Time After: 0.01990 seconds
Time Before: 0.02067 seconds
Time After: 0.02337 seconds
Time Taken: 0.00270 seconds
Time Before: 0.01997 seconds
Time After: 0.02747 seconds
Time Taken: 0.00750 seconds
Time Before: 0.03299 seconds
Time After: 0.03344 seconds
Time Before: 0.03627 seconds
Time After: 0.03750 seconds
Time Before: 0.03224 seconds
Time After: 0.03771 seconds
Time Taken: 0.00547 seconds
Memory After: 2,885.219 KB
Memory Used: 132.898 KB
Time Before: 0.05861 seconds
Time After: 0.05876 seconds
Memory Before: 3,438.320 KB
Memory After: 3,438.836 KB
Time Before: 0.06691 seconds
Time After: 0.06822 seconds
Time Taken: 0.00132 seconds
Memory Before: 3,526.016 KB
Memory After: 3,526.609 KB
End call of global.php: 0.070178031921387
Time Before: 0.07398 seconds
Time After: 0.07419 seconds
Memory Before: 4,163.914 KB
Memory After: 4,164.344 KB
Time Before: 0.07717 seconds
Time After: 0.07865 seconds
Memory Before: 4,445.453 KB
Memory After: 4,447.141 KB
SET lastactivity = 1784773618, location = '/forums/private.php?do=newpm&explain=1&u=18242'
Time Before: 0.09679 seconds
Time After: 0.09709 seconds
Memory Before: 4,911.148 KB
Memory After: 4,911.375 KB
Page generated in 0.095637083053589 seconds with 9 queries, spending 0.0084640979766846 doing MySQL queries and 0.087172985076904 doing PHP things.
