Time Before: 0.01931 seconds
Time After: 0.02468 seconds
Time Taken: 0.00537 seconds
Memory Before: 1,157.773 KB
Memory After: 1,182.891 KB
Time Before: 0.02475 seconds
Time After: 0.02519 seconds
Memory Before: 1,182.828 KB
Memory After: 1,183.836 KB
Time Before: 0.02567 seconds
Time After: 0.02584 seconds
Memory Before: 1,184.422 KB
Memory After: 1,184.945 KB
Time Before: 0.02656 seconds
Time After: 0.02914 seconds
Time Taken: 0.00258 seconds
Memory Before: 1,187.547 KB
Memory After: 1,188.469 KB
Time Before: 0.02591 seconds
Time After: 0.03347 seconds
Time Taken: 0.00757 seconds
Memory Before: 1,184.164 KB
Memory After: 2,265.219 KB
Memory Used: 1,081.055 KB
Time Before: 0.04138 seconds
Time After: 0.04181 seconds
Memory Before: 2,758.023 KB
Memory After: 2,758.641 KB
Time Before: 0.04413 seconds
Time After: 0.04540 seconds
Memory Before: 2,770.078 KB
Memory After: 2,769.938 KB
Time Before: 0.04069 seconds
Time After: 0.04563 seconds
Time Taken: 0.00495 seconds
Memory Before: 2,750.172 KB
Memory After: 2,883.297 KB
Memory Used: 133.125 KB
Time Before: 0.08077 seconds
Time After: 0.08099 seconds
Memory Before: 3,436.438 KB
Memory After: 3,436.953 KB
Time Before: 0.09936 seconds
Time After: 0.10078 seconds
Memory Before: 3,524.234 KB
Memory After: 3,524.828 KB
Time Before: 0.10824 seconds
Time After: 0.10843 seconds
Memory Before: 4,162.117 KB
Memory After: 4,162.547 KB
Time Before: 0.11078 seconds
Time After: 0.11239 seconds
Time Taken: 0.00160 seconds
Memory Before: 4,443.680 KB
Memory After: 4,445.367 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=18247' WHERE sessionhash = '87651ca345a619a09949038b7f47c9ec'
Time Before: 0.13139 seconds
Time After: 0.13168 seconds
Memory Before: 4,921.695 KB
Memory After: 4,921.938 KB
