Time Before: 0.01985 seconds
Time After: 0.02561 seconds
Time Taken: 0.00576 seconds
Time Before: 0.02571 seconds
Time After: 0.02615 seconds
Time Before: 0.02641 seconds
Time After: 0.02656 seconds
Time Before: 0.02726 seconds
Time After: 0.02993 seconds
Time Taken: 0.00268 seconds
Time Before: 0.02661 seconds
Time After: 0.03426 seconds
Time Taken: 0.00764 seconds
Time Before: 0.03984 seconds
Time After: 0.04028 seconds
Time Before: 0.04324 seconds
Time After: 0.04450 seconds
Time Before: 0.03919 seconds
Time After: 0.04470 seconds
Time Taken: 0.00551 seconds
Time Before: 0.07979 seconds
Time After: 0.07993 seconds
Time Before: 0.09267 seconds
Time After: 0.09391 seconds
End call of global.php: 0.096063852310181
Time Before: 0.10224 seconds
Time After: 0.10246 seconds
Time Before: 0.10473 seconds
Time After: 0.10627 seconds
Time Taken: 0.00154 seconds
SET lastactivity = 1776637009, location = '/forums/private.php?do=newpm&explain=1&u=18433'
Time Before: 0.12847 seconds
Time After: 0.12883 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.12719678878784 seconds with 9 queries, spending 0.0084700584411621 doing MySQL queries and 0.11872673034668 doing PHP things.
