Time Before: 0.00142 seconds
Time After: 0.00196 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00203 seconds
Time After: 0.00264 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00286 seconds
Time After: 0.00297 seconds
Time Before: 0.00374 seconds
Time After: 0.00616 seconds
Time Taken: 0.00242 seconds
Time Before: 0.00302 seconds
Time After: 0.00948 seconds
Time Taken: 0.00646 seconds
Time Before: 0.01123 seconds
Time After: 0.01172 seconds
Time Before: 0.01485 seconds
Time After: 0.01605 seconds
Time Before: 0.01066 seconds
Time After: 0.01622 seconds
Time Taken: 0.00556 seconds
Time Before: 0.02124 seconds
Time After: 0.02144 seconds
Time Before: 0.02330 seconds
Time After: 0.02463 seconds
Time Taken: 0.00133 seconds
Time Before: 0.02766 seconds
Time After: 0.02786 seconds
Time Before: 0.02991 seconds
Time After: 0.03134 seconds
UPDATE session SET lastactivity = 1783086547, location = '/forums/private.php?do=newpm&explain=1&u=18444' WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.04358 seconds
Time After: 0.04395 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
